engine rebuild questions
Old Nov 21, 2013 | 07:29 PM
  #21
Spillage's Avatar
Spillage
A clogged cat will really make for "no guts"... if you've had a plenum problem for any length of time, chances are the cat is toast.
And "cat cleaning" is only to remover contaminants... it won't fix a melted core... in fact "cleaning" not done right will cause a meltdown.
Similarly, a bad O2 will also lead to killing the cat.
Old Nov 21, 2013 | 10:22 PM
  #22
dieselsuburban95's Avatar
dieselsuburban95
The cat is gutted im gonna look at the plenum tomorrow with a magnetic
Old Nov 22, 2013 | 11:38 PM
  #23
dieselsuburban95
I just order the aluminum plenum and gasket kit from Hughes gona try that and a tune up has anyone ever took the injectors apart and cleaned them
Old Nov 23, 2013 | 12:10 PM
  #24
I think injectors are fairly non-serviceable without some interesting tools.... but, not 100% on that. There are places you can send them out to, to be cleaned, and balanced. That was the route I was considering taking. (as I have a couple extra sets of injectors.....)
Old Nov 23, 2013 | 12:31 PM
  #25
dhvaughan's Avatar
dhvaughan
no personal experience but some people use a sonic jewelry cleaner to clean them. i don't know if it really works or not but it used to be a popular topic.
Old Nov 23, 2013 | 12:39 PM
  #26
merc225hp's Avatar
merc225hp
There are filters in the top of each injector that can be replaced I would do that at least.
Old Nov 23, 2013 | 06:59 PM
  #27
dieselsuburban95
Ok ill look at that when I do the plenum
Old Dec 17, 2013 | 04:28 PM
  #28
dieselsuburban95
Ok so I pulled the intake to day the plenum is shot im gona clean the intake today and put it back on tomorrow
Old Dec 17, 2013 | 04:41 PM
  #29
dieselsuburban95
This is what it looked like in there
Old Dec 17, 2013 | 06:23 PM
  #30
Yep, that ones blown.
