need help with a freeze plug
Old Nov 21, 2013 | 07:32 PM
CoryVolkenant's Avatar
CoryVolkenant
Default need help with a freeze plug
so my freeze plug behind driver side motor mount is leaking i have had the motor mount off when truck was on the ground how the heck do you get to that plug? i put the motor mount back on im gonna take the truck out to my brothers place he has a two post lift im not sure if in the air will help, i know this topic has beet gone over many times just looking for some help i gotta be at work at 2am tomorrow then gonna haul truck on a trailer to the lift any ideas how to get to that would be great, also gonna do a 4 in lift kit and plenum and 1 ton steering at the same time so i dont know if doing 1 or the other at the same time will make anything easier or different thanks for any advice in advance
Old Nov 22, 2013 | 01:17 AM
master tech's Avatar
master tech
Site Moderator & Tech
There is a freeze plug tool that has a handle and adapters to install the freeze plugs.
Old Nov 22, 2013 | 06:46 AM
AtomicDog's Avatar
AtomicDog
Should be able to get to it easier on a lift after putting a screw jack under the oil pan, removing the motor mount and jacking the motor up a bit on that side. Would be good to have a picture of that area to see exactly what the issue may be.
Old Nov 22, 2013 | 10:39 AM
For that freeze plug, I just supported the engine on a jack, pulled the motor mount, drove a big screwdriver thru the plug, and levered it out. (doesn't matter if you destroy the plug taking it out, not like you need to reinstall it.)
Once it was out, I hit the hole with some sandpaper, put a bead of RTV around the sealing surface of the freeze plug, and used a large half-inch socket, and a six inch extension as a driver. Worked great. Let it sit for an hour for the RTV to cure, put it all back together, added coolant, and down the road I went.
