tranny problem ?
Old Nov 21, 2013 | 10:08 PM
huntinrig's Avatar
huntinrig
Default tranny problem ?
just had the tranny rebuilt . did a complete tune up. when driving it seems like it shifts real fast. it feels like im in overdrive at 40 mph and has no power. when I kick it down, it down shifts for a second and then falls flat on its face, no power. when I did the tune up I found rust in the distributor on the timing advance. I cleaned it off the best I could but it still has some on it . cold this be the problem ? do I need a new dis. shaft ? any help would be very helpful . THANKS
Old Nov 21, 2013 | 10:36 PM
moe7404's Avatar
moe7404
i dont know you engine or trany. but it sounds like the linkage or cable going to the trany from the throttle body is miss adjusted. i think it is set to lite, readjust it to pull more on the trany. if you can find the factory setting should be good for most people. years ago i would reset them and even mod them. but i dont recommend that for most people.
Old Nov 21, 2013 | 10:37 PM
Arde's Avatar
Arde
Check your TV cable adjustment, if that isn't it, take it back to the rebuilder.
Old Nov 21, 2013 | 10:45 PM
huntinrig's Avatar
huntinrig
its a 318 I cant remember the tranny . the shop said it was a 5 speed ?
Old Nov 21, 2013 | 10:50 PM
Arde's Avatar
Arde
What year is your truck?
Old Nov 21, 2013 | 10:57 PM
If you just paid big bucks to have it rebuilt, take it back, show them the problem, have THEM fix it.
Old Nov 21, 2013 | 11:07 PM
huntinrig's Avatar
huntinrig
sorry guys its a 2001 ram 1500. I told them about it they said I had a bad miss. I then did the tune up . the mechanic took it for ride said it was fine dumb a##. Ill take it back and go with him for a ride. thanks for the help
Old Nov 22, 2013 | 01:11 AM
master tech's Avatar
master tech
Site Moderator & Tech
If the truck has lack of power, you may have a plugged exhaust system.
