Service A/T
Old Nov 23, 2013 | 09:49 AM
Linetrash's Avatar
Linetrash
Default Service A/T
All~ I'm dropping my transmission pan on a 47RE early 98 12 valve. While I'm inside the cover I would replace filter, and the solenoid and Governor and adjust the bands. My question is what are the correct solenoids to replace. Lock up solenoid complete w/OD and the Governor pressure solenoid? Is there an output sensor also? Best fluid? Also are the after market parts more robust than OEM. Additionally where to purchase, Thanks
Old Nov 23, 2013 | 12:15 PM
Borg Warner makes a 'heavy duty' governor solenoid, there is a seller on Ebay that has them, with a new pressure sensor as well, for around 100 bucks.
Use ONLY ATF +4 trans fluid. Brand is pretty much irrelevant. Wal-Mart has it for cheap. (relatively speaking.)
Other solenoids are TCC, and O/D. If they aren't causing a problem, I wouldn't bother replacing them. No heavy duty units in the aftermarket I am aware of.
Make sure to have six to eight quarts of fluid on hand when you drop the pan. Some seem to take more to refill than others.
Old Nov 24, 2013 | 10:15 AM
Linetrash's Avatar
Linetrash
Default A/T Service
Thanks I'll look up solenoids on E-bay
Old Nov 24, 2013 | 02:51 PM
moe7404's Avatar
moe7404
i found an external filter check it out. my idea is that you wont have to go into the inside filter as often. been using one for 2 years.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com
2. for other sizes wix 58964 5/16 tube size
