po441 Please help
Old Nov 25, 2013 | 04:18 PM
wenzel5.9ram's Avatar
wenzel5.9ram
Default po441 Please help
I have a 97 ram 5.9 and about a week ago my engine light came on with the code po441 and i replaced the gas cap and the throttle body vac line as it was cracked, i un hooked my battery to clear the code and all was good until it turned on today, where do start?
Old Nov 25, 2013 | 04:50 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Check the soft line from the charcoal canister.
Old Nov 25, 2013 | 05:06 PM
wenzel5.9ram
Is this the bigger or smaller line
Old Nov 25, 2013 | 06:17 PM
NJphil's Avatar
NJphil
Default 441
With mine ,it was the fill neck that was rotted
Old Nov 25, 2013 | 06:40 PM
wenzel5.9ram
I just looked at mine and i seems fine was there a hole or what?
Old Nov 25, 2013 | 08:16 PM
Probably dry rot. It IS 16 years old.
Check ALL the vacuum lines in the evap system. Including the fill tube, and vent line on the tank. Make sure the canister isn't cracked, or puking charcoal into the lines.
Old Nov 25, 2013 | 08:57 PM
wenzel5.9ram
I have taken a decent look at the line and when i was checking how tight the lines were to the evap canister i pulled off the small line and it had charcoal all up in it, poured a little out. Whats that mean?
Old Nov 26, 2013 | 12:03 AM
dhvaughan's Avatar
dhvaughan
the charcoal part should be sealed and should not be up in the vac line. i think that means you need a new one from the junk yard.
here's the p0441 info.
https://dodgeforum.com/forum/2nd-gen...-leak-fix.html
Old Nov 26, 2013 | 10:15 AM
97r/tram's Avatar
97r/tram
Yeah you can't find any charcoal canisters in the parts stores or they're like $200 from chrysler. The 94-97 and the 98-02 are different.
Old Nov 27, 2013 | 11:16 PM
J415's Avatar
J415
i bought my charcoal canister from the stealership for $48
