need some help with coolent hose
Old Dec 1, 2013 | 12:12 PM
dieselsuburban95's Avatar
dieselsuburban95
Default need some help with coolent hose
Ive got a leak on my heater hose where it goes back behind the altnater does anyone know how hard this is to change out
Old Dec 1, 2013 | 12:35 PM
I don't think you even need to remove anything to get to it. Shouldn't be much more than a 20 minute job. (getting the hose off the nipple is the hardest part.....)
Old Dec 1, 2013 | 12:52 PM
dieselsuburban95
I cant see any way to get to it other than pull the altnater ill look at it again
Old Dec 1, 2013 | 02:49 PM
dman12323's Avatar
dman12323
When my hose had a hole in it like that I removed the alternator and top section and cut the hose off of the nipple and re-installed everything. Took about max of 3 hours.
Old Dec 1, 2013 | 06:28 PM
dieselsuburban95
I pulled the line and couldn't find any hole or split lookes brand new I think its my upper radiator hose
Old Dec 1, 2013 | 06:49 PM
Where is the coolant dripping from?
Old Dec 1, 2013 | 07:46 PM
dieselsuburban95
I pulled the altnater and I could see rust on the cup or the thermostat housing but its dripping from the center of the block some where
Old Dec 2, 2013 | 09:09 AM
97r/tram's Avatar
97r/tram
It's most likely the coolant bypass hose from the intake to the water pump. Bad water pumps leak like a faucet. Bypass hoses trickle.
Old Dec 2, 2013 | 11:31 AM
dieselsuburban95
Its more like a faucet im gona replace it anyway
Old Dec 2, 2013 | 11:54 AM
97r/tram's Avatar
97r/tram
You'll have to pull the accessory bracket off and water pump to change the bypass hose.
