price to fix leaking wheel cylinder?
Old Dec 16, 2013 | 01:40 PM
2000ramsport's Avatar
2000ramsport
Default price to fix leaking wheel cylinder?
my rear brake on the passenger side has a leaking wheel cylinder what would a shop charge me to fix it?
Old Dec 16, 2013 | 02:08 PM
stewie01's Avatar
stewie01
$1000
Wheel cylinder replacement isn't that big a deal, if you have a few hand tools you can do it for the price of the replacement part...
But in all seriousness I would think you'd see 1hr labor charge at an honest shop..... (plus part)
Old Dec 16, 2013 | 02:53 PM
Gotta bleed the brakes too.... so, probably three hours labor, wheel cylinder, and brake fluid.
Of course, the shop will want to sell you rear shoes too..... and probably some brake lines.
if you have the tools, and a place to work on it, do it yourself. Otherwise, probably around 200 or so. (probably more.)
Old Dec 16, 2013 | 03:26 PM
You can get a wheel cylinder for as low as $2.95 from rock auto, probably like $15 from an autoparts store. Unbolt the old one and quickly install the new one, limiting the amount of time the brake line is disconnected. You should only have to bleed that one wheel cylinder. I replaced one on my truck and it took maybe an hour at the most, including bleeding.
Old Dec 16, 2013 | 03:59 PM
Thornloe Pride's Avatar
Thornloe Pride
Replacing a wheel cylinder isn't that bad. You don't need a lot of knowledge to do it yourself and you could save a couple hundred possibly. Lots of guys here can help you through it
Old Dec 16, 2013 | 07:37 PM
dhvaughan's Avatar
dhvaughan
here's some pics for you.
https://dodgeforum.com/forum/2nd-gen...-pictures.html
