Low Air Flow from HVAC
Old Dec 19, 2013 | 12:15 PM
johnkatos's Avatar
johnkatos
Default Low Air Flow from HVAC
1997 Ram 1500 5.9L A/T 170,000 miles, purchased new.
I have low flow coming out of the heater vents. The mode switch works O.K. feet, dash, feet + dash, defrost, recirc all behave properly. The fan speed changes and the flow changes, but the flow is very much reduced.
Thanks
John Katos
Old Dec 19, 2013 | 12:16 PM
Got leaves and such clogging the intake?
Can drop the blower motor, and have a look inside, see if you have a bunch of trash up against the a/c evaporator core.... (it's RIGHT there by the fan.)
Old Dec 19, 2013 | 01:31 PM
Ham Bone's Avatar
Ham Bone
Yep there's not a can filter or anything like that. It loves to suck up leaves
Old Jan 4, 2014 | 11:23 AM
wollman's Avatar
wollman
Can snow do the same thing-like the leaves? I am getting no air coming out of my vents but it sure sounds like it is working. I can switch high to low but still no air.
2007 Dodge Ram Hemi
Old Jan 4, 2014 | 12:51 PM
Anything can block air flow. See if you can't clean everything off, and take it from there. If that doesn't help, post up in the third gen ram section. I think your system is somewhat different than ours.
Old Jan 4, 2014 | 01:34 PM
wollman's Avatar
wollman
Thanks, I will try that.......stupid question.......I am a girl and what is third gen ram mean?
Old Jan 4, 2014 | 01:39 PM
The only stupid question is one that isn't asked.
Rams currently have four "generations". From the main forum page, if you click on the "Ram Trucks" header, it will show all four generations of ram trucks (complete with pics!) and what years they are. First gen goes to 93, second gen is 94-2001, 3rd gen is 2002 to 2008? I think.
Old Jan 4, 2014 | 01:40 PM
You think?
@Wollman, 3rd gen Ram is here >> https://dodgeforum.com/forum/3rd-gen-ram-tech-65/
Although common problems may go across "generation" lines, the guys in the 3rd gen section can help you with specifics.....they can help you better as they drive and work on the same "generation" of Ram as yours. Welcome to the forum!
Old Jan 4, 2014 | 01:59 PM
Originally Posted by jkeaton
You think?
it happens once in while, don't tell anyone though........
