LED feet lights
Old Dec 29, 2013 | 11:46 PM
Tyler Springhetti's Avatar
Tyler Springhetti
Question LED feet lights
I am trying to install LED strips to they shine by your feet inside the cab. I am not familiar with the wiring in the truck so I am not sure where to acces a power source close to the place they will be.
Any help or advice would be appreciated.
Old Dec 30, 2013 | 12:18 AM
master tech's Avatar
master tech
Site Moderator & Tech
Do you want it to light up when you turn the ignition on or the headlamps?
Old Dec 30, 2013 | 08:28 AM
AtomicDog's Avatar
AtomicDog
Based on what he stated, perhaps the new LED light strips should activate when either truck door is opened?
Old Dec 30, 2013 | 10:26 AM
G0083RNUT5's Avatar
G0083RNUT5
I have mine wired into my radio an grounded to the steel running under the steering wheel. Works great. It comes on whenever the truck/radio is on. Took 20min tops.
Old Dec 30, 2013 | 11:20 AM
Tyler Springhetti
I would love it to work when the doors are opened but if its not possible then any other way will be fine.
Old Dec 30, 2013 | 11:49 AM
stewie01's Avatar
stewie01
Probably need to tap into the wiring that overhead light is wired into, since it comes on when you open the door.
Wiring diagram in the Factory Service Manual in the DIY/FAQ section
Old Dec 30, 2013 | 11:58 AM
I think the door switches ground the circuit.... so, wire the lights to constant power, and run the ground to the door switch. Lites on with door open.
Old Dec 30, 2013 | 12:19 PM
95' 360 Ram's Avatar
95' 360 Ram
I would say just look for the little switch that spring out when the door is open to turn on the entry lighting and just tie in there.
Old Dec 30, 2013 | 12:59 PM
Tyler Springhetti
I have tried to take that switch out but could not get it out (or could not figure out how to do it)
Old Dec 30, 2013 | 01:12 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
It's a friction fit. Pushes/pulls right out.
