please help
Old 01-04-2014 | 10:41 AM
Does the truck lurch forward a bit when that happens? If so, I would suspect the torque converter has permanently locked up......
You could try disconnecting the 8 pin connector on the drivers side of the trans, 'bout half way back, and see if that makes any difference. (in case it is simply an electrical problem.)
Old 01-04-2014 | 10:37 PM
dustybo83's Avatar
dustybo83
No it doesn't lurch, it just dies. I've tried running the RPMs up and dropping it in gear and its still like you turn the key off once you put it in gear
Old 01-04-2014 | 10:46 PM
Will it do the same if you put it in neutral?
Old 01-05-2014 | 06:58 AM
dustybo83's Avatar
dustybo83
Runs fine in neutral
Old 01-05-2014 | 02:55 PM
That's not a good sign.......
What about reverse? Can you back up? If not, I don't think you have an engine problem, I think you have a trans problem.
Old 01-05-2014 | 10:41 PM
dustybo83's Avatar
dustybo83
Dies soon as its put in reverse. I can see where your going with that, but didn't explain why it only starts once in a while
Old 01-06-2014 | 09:02 AM
redneck_ram's Avatar
redneck_ram
Do the v10s have crank sensors? Sounds like a typical crank sensor issue...
Old 01-06-2014 | 10:28 AM
I think you have two separate problems.
Old 01-07-2014 | 02:56 PM
dustybo83's Avatar
dustybo83
Yea it has a crank Sensor
