reverse lights
Old Jan 4, 2014 | 01:06 PM
CrushinDozer's Avatar
CrushinDozer
Default reverse lights
My reverse lights barely blink on when i put the truck into reverse. any clues as to why?
'98 1500 Laramie, 5.9L
Old Jan 4, 2014 | 01:35 PM
Probably need to adjust the linkage, either that, or the switch is going bad. (is right on the trans, where the shift linkage hits the trans.
Old Jan 4, 2014 | 02:02 PM
CrushinDozer
How hard would that be to adjust?
Old Jan 4, 2014 | 02:14 PM
Not too bad, procedure is in the service manual. You can download one from the FAQ section here. Probably takes longer to get the truck someplace to work on it, grab the tools, and crawl under there, than it does to actually do the job.
Old Nov 14, 2014 | 10:12 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
hmmmmm, may start here first as I've just noticed my reverse lights don't come on. All other lights work properly.
Old Nov 14, 2014 | 05:07 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
All working now.
Old Nov 14, 2014 | 07:02 PM
Just a blown fuse? Gotta love the easy ones.
Old Nov 15, 2014 | 10:40 PM
ryan0714's Avatar
ryan0714
if they are coming on, but not bright it could be a crappy ground also... just throwin it out there
Old Nov 16, 2014 | 02:29 PM
dean98ram1500's Avatar
dean98ram1500
When I first got my truck, I didn't have reverse lights at all. Replaced the Safety Neutral switch and we were all back in action!
Old Nov 16, 2014 | 09:57 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Good point on the ground. I was trying to think back the last time I noticed any issue and it was buddy's trailer. We had to DC some lights.
Anyways, all good for now.
