Troubleshooting fuel pump
Old Jan 4, 2014 | 09:21 PM
pipeking's Avatar
pipeking
Default Troubleshooting fuel pump
so, I found the fuel pump relay (can't believe I missed it the first time and posted)!
in PDC I do have consent power at pin 30 and have no power at pin 85 UNTIL I turn the key on. I do have ground at pin 86. I put a jumper between 12v power and pin 87 and nothing. I do have a fuel rail gauge and I also used a amp meter to test load of fuel pump, nothing. so does this mean the fuel pump is shot?
Old Jan 4, 2014 | 09:51 PM
If you have good twelve volts at pin 30, and jumping to 87 didn't make the pump run, yep, the pump is shot.
Old Jan 4, 2014 | 10:12 PM
pipeking's Avatar
pipeking
new pump, can't wait! it so cold right now in CT.
Old Jan 4, 2014 | 10:14 PM
Wait. What? You expect your truck to wait for nice weather to require repairs????? You should know by now it seldom works that way.
Old Jan 4, 2014 | 10:21 PM
snowboundrmk's Avatar
snowboundrmk
Don't forget to only get a Denso or Delphi brand pump.
Old Jan 5, 2014 | 10:37 AM
pipeking's Avatar
pipeking
ok I seen a lot of the stuff in the truck is Delphi so I will go with that, from summit.
