Old Aug 10, 2015, 06:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
Tire tread
Old Jan 7, 2014 | 11:50 PM
Rodo1994's Avatar
Rodo1994
Default Tire tread
Is it smart or safe for differential, for a truck to ride on tires with different tread?
I.e-
one tire is almost new, 85ish
Two are about 65%
And the last is 40ish
Old Jan 8, 2014 | 01:33 AM
Dieselweasle's Avatar
Dieselweasle
As long as they are the same size tire, the amount of tread won't put too much stress on the diffs.
Old Jan 8, 2014 | 01:57 AM
Rodo1994's Avatar
Rodo1994
They are all the same size, 33x12.50r15
Just tread is a mix range from 90% as low as 40%.
The one with the most and least tread won't be an issue?
Old Jan 8, 2014 | 02:04 AM
Dieselweasle
Put the lower treads on the front and the best on the rear. Since they're probably mudders, with big lugs, that can make a bit of a difference, but nothing drastic that will eat the diff.
Old Jan 8, 2014 | 11:09 AM
BrandonBuc'em's Avatar
BrandonBuc'em
you might just notice it pull to one direction.
Old Jan 8, 2014 | 01:29 PM
Rodo1994's Avatar
Rodo1994
Wouldn't that slowly run my alignment out of line? Even if I put the better and worst treaded tires on the back.
Old Jan 8, 2014 | 01:56 PM
Pull comes from uneven tire wear (in this instance). Either between the two steering tires, or, simply on one tire. Alignment is purely mechanical. If you get a pull, that will give you accelerated tire wear, but, won't hurt your alignment.
Old Jan 8, 2014 | 04:00 PM
Rodo1994's Avatar
Rodo1994
So all tires, or only the one with more tread will wear faster?
