1740 help
Old Jan 12, 2014 | 11:36 AM
buggs's Avatar
buggs
Question 1740 help
read a lot about the 1740 code but my 2000 ram 2500 4x4 has different symptoms it will shift when I first start out in the morning as it warms up it wont shift out of first gear unless I manually shift or if I start out at a red light or stop sign and I put it in neutral then drive shifts perfect till the next light any ideas
Old Jan 12, 2014 | 11:37 AM
Drop the pan, clean or replace the governor pressure sensor/solenoid.
Old Jan 12, 2014 | 11:40 AM
buggs's Avatar
buggs
replaced them already ran good for a week
Old Jan 12, 2014 | 11:45 AM
Need to find out what changes when it warms up then. Might be the output speed sensor as well. Got a scanner you can plug in, and look at live data while driving?
Old Jan 12, 2014 | 11:48 AM
buggs's Avatar
buggs
thinking torque converter or tcc od sensor but overdrive works fine rpm aren't jumpin around
Old Jan 12, 2014 | 11:53 AM
buggs's Avatar
buggs
what gets me is whenever I start off from a light if I hit neutral first truck shifts fine oh and I drilled out the one way ball
Old Jan 12, 2014 | 11:56 AM
buggs's Avatar
buggs
if I disconnect the battery the check eng light will go out but come back on after 20 or so miles
Old Jan 12, 2014 | 02:28 PM
buggs's Avatar
buggs
anybody? anything? is MONTEC out there
Old Jan 12, 2014 | 02:54 PM
1740 is for TCC and O/D solenoid performance. Basically, the PCM is grounding circuits, but, not seeing the RPM drop it thinks it should. This is a separate issue from not wanting to shift when warm. Could probably fix that one simply by replacing the solenoid set. (well, 'simply' is a relative term here.)
