Problems with Removing Body Lift... again.
Old Jan 15, 2014 | 10:03 PM
Matthix's Avatar
Matthix
Default Problems with Removing Body Lift... again.
I have removed a 3 in. body lift that was on my truck and replaced the bolts on the cab and replaced all extended parts. But now that the lift was removed from the bed, the back of the bed sits higher than the front of the bed. It doesn't fit down properly. Am I missing stock mounts for the bed? Any help would be much appreciated
Old Jan 15, 2014 | 10:08 PM
There were some hockey pucks under there from the factory. The bed didn't sit directly on the frame.
Old Jan 15, 2014 | 10:15 PM
Matthix's Avatar
Matthix
ok thank you. The thing I don't understand is if the bed is raised any the grooves on the side of my truck will not line up with the cab's. I bought new rubber mounts for the cab so I know it's done correctly, or atleast as correct as it can be with me doing it
Old Jan 15, 2014 | 10:19 PM
The body lines should line up...... if they don't, something is awry. Can you see what the bed is hitting on? Miss a spacer or two while you were under there??
Old Jan 15, 2014 | 10:30 PM
Thornloe Pride's Avatar
Thornloe Pride
Post up some pics when you can.
Old Jan 15, 2014 | 11:12 PM
Matthix's Avatar
Matthix
Too dark for pics tonight, I'll try to get some up ASAP after work tomorrow. The only thing I can see that the bed is hitting is the gas tank. So a spacer or a mount has to be missing, huh?
Old Jan 17, 2014 | 01:01 AM
Matthix's Avatar
Matthix
Sorry for the late update. Went to the salvage yard and looked at other trucks like mine and turnes out no mounts for the bed. When I got off I realized the back bumper had been raised and the body was sitting on the brackets that raised it. It was too dark last night to see. Dropped it, lined it up and bolted down the bed so everything is done. Thanks again for the help
Old Jan 17, 2014 | 11:23 AM
Cool. We still want pics.
Old Jan 17, 2014 | 04:03 PM
Johnn123's Avatar
Johnn123
+1!!
Glad ya got it figured out!
