I had to drill one out unfortunately, all the corner bolts were either broke off already or messed up, vise grips got 3 out though. Just wondering what size the threads are because I got the hughes bolts and not for sure what tap to use
If there is any of it left sticking out, clean out the hole it goes into really well, (around the bolt there is a recess, of sorts, it packs full of crap.) Drown it with chems, put a pair of vice grips on it as tight as you can, and try and work it back and forth a bit while tapping on the end with a hammer. Takes a bit, but, it WILL break loose, and then it comes right out.
I already drilled it out, but yeah it definitely isn't completely center. Part of the bolt is still in the whole, like eroded but I think it would work if I could just tap the same size right now...
how are you gonna put a bolt thru the manifold and into the block if its not straight. u really should sit the manifold back on it, and take ur drill down thru the manifold hole and drill ur hole into the block, so its straight this way.
