Engine dilemma
Old 01-19-2014, 10:43 PM
Hedrock's Avatar
Hedrock
Hedrock is offline
Default Engine dilemma
Hey guys... I would appreciate some advice on an engine dilemma that I have. I have a 98 3/4 ton 4x4 that currently has a 5.2 engine in it with a known 95k miles on it. This engine is not original to the truck but has been in it for the last 2 years. I just recently bought a 5.9 that has unknown miles and condition but has EQ heads with stainless valves. The heads have been on the 5.9 for about a year (receipt dates). I guess my questions would be...
Should I put the EQ heads on the 5.2 or do I take a chance on the 5.9?
How much power difference is there between the two?
Currently there are no other mods done to the truck except the plenum fix. I would however like to put on some shorty headers and replace the "y" pipes when I do this engine work. The truck is basically a daily driver and I tow with it on occasion but it's only a vw on a car hauler trailer.
Thank you very much for any advice or comments you are willing to share.
Brian
Old 01-20-2014, 01:44 AM
Ram Driver's Avatar
Ram Driver
Ram Driver is offline
Others here know a lot more than me, but from what ive read here there is not much of a horsepower or torque difference between the two engines. I would just swap the heads and call it good.
Old 01-20-2014, 10:16 PM
Hedrock's Avatar
Hedrock
Hedrock is offline
Thank you Ram Driver. That's kind of the direction I wanted to go. I just wasn't sure how much difference there was between the two in power.
Brian
Old 01-20-2014, 10:21 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
5.9 thats a given. Has a comp test been done on either motor?
Old 01-20-2014, 10:33 PM
Hedrock's Avatar
Hedrock
Hedrock is offline
No compression check on either engine. The 5.2 runs decent, it just uses coolant. I basically bought the 5.9 for the heads. It rotates freely on the stand and doesn't appear to have excessive junk inside. I just don't really know much more about it.
Old 01-20-2014, 10:36 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
A 5.2 is a mighty small motor in a 3/4 ton truck, especially when towing or hauling a heavy load. I would not hesitate to put the 5.9 with EQ heads in that truck. Must be a reason the EQ heads were put on the 5.9 - likely to cure the coolant leak issue you're experiencing with the 5.2 (cracked head/blown head gasket)...
Old 01-20-2014, 10:40 PM
merc225hp's Avatar
merc225hp
Me I would take the gamble and install the 5.9. Probably less time to install it then swapping the heads.
Old 01-20-2014, 10:44 PM
Hedrock's Avatar
Hedrock
Hedrock is offline
The previous owner replaced the heads due to cracks last summer. Later he decided to make his truck into a rock crawler and takes the 5.9 out and puts in a Chevy 454. I saw his truck with the 454 in it and it almost looked like it was supposed to be there.
Old 01-20-2014, 10:55 PM
merc225hp's Avatar
merc225hp
By myself I can swap a motor in these trucks in 6 hrs. When I changed the heads with the motor in the truck, every last thing ready parts wise it was close to a 15hr job. You might be able to cut some time of that head swap as I have a F***** neck and back.
Old 01-20-2014, 11:02 PM
Hedrock's Avatar
Hedrock
Hedrock is offline
Looks kike I need to dig into the 5.9 more.
Quick Reply: Engine dilemma
