Funky brake problem
Old Jan 21, 2014 | 01:39 PM
pilsbury88's Avatar
pilsbury88
I get absolutely no dash warning lights when this phenomenon happens. It seems to happen when the truck is cold and after it warms up. It doesn't seem to matter. Guess I'll have to get to Advance and inquire about their scanners. Thanks guys. If/when I find the solution I'll post it here.
Old Jan 21, 2014 | 03:38 PM
You can verify if the noise you hear is the antilock dance, simply by going to a parking lot somewhere, running it up to about 30 miles an hour, and standing on the brake. If you get the same type of noises, chances are good you have an abs problem.
Old Jan 21, 2014 | 07:08 PM
pilsbury88's Avatar
pilsbury88
I'll try that. I've only had it happen when I'm gently pressing the brakes coming to a stop. Granted, I don't make a habit out of slamming them so maybe it will happen then as well.
Old Jan 23, 2014 | 03:40 AM
pilsbury88's Avatar
pilsbury88
I did some of what you suggested - slamming on the brakes from about 30mph. No odd results. Nothing like the problem I originally posted about. The brake pedal did seem to lift back up to its original position slower than normal. Maybe that has something to do with the temperature being in the negative digits here.
Old Jan 23, 2014 | 11:00 AM
Yeah, I don't like the cold either. Probably shouldn't expect our trucks to.....
Talk to your favorite local parts store, ask if their scanners can read abs codes/data. If it can, plug one in, and go for a ride. (bring someone else along to monitor scanner. Safer that way.)
Old Jan 23, 2014 | 12:16 PM
Ham Bone's Avatar
Ham Bone
None of the local parts store down here will read abs codes for some reason or another. I guess so they dont tell your brakes are fine and then you hit a telephone pole and sue the crap out of them
Ive had success with the local garages reading them for me, well Ive only had to do it once
Old Aug 2, 2016 | 03:36 PM
Jimythefan's Avatar
Jimythefan
Okay, kicking this one to the top rather than start another abs thread. Pilsbury never updated so I don't know if he resolved his issue.
My truck recently started doing the abs dance thing intermittently. When coming to a stop sometimes the abs system kicks in as if the truck is sliding on ice. No abs light, speedo works fine, and brake system is in excellent shape. (4 wheel abs system) I'm guessing one of the sensors has gone bad since no abs light comes on when it happens. I checked and cleaned the connectors for the sensors, but it's still happening. Does anyone know if the scanners will do real time data trapping?
Old Aug 2, 2016 | 03:43 PM
pilsbury88's Avatar
pilsbury88
My problem ended up being a bad wheel speed sensor in the front left hub. You need a scanner that will read live ABS data to properly diagnose it. I used a Snap On Solus. As you're driving you need to have someone look at the wheel speeds. The good sensors will remain steady (and agree with your speedometer within reason) and the bad sensor will bounce all over the place. That's likely your problem.
Old Aug 2, 2016 | 04:27 PM
Jimythefan's Avatar
Jimythefan
Saweeeet! Thank you for that, and quick answer too. Now I have a starting point. I'll update when I get it fixed.
Thanks Pilsbury.
Old Aug 4, 2016 | 04:52 PM
Jimythefan's Avatar
Jimythefan
Front left bad on mine too. Replacement on the way from rockauto.
Thanks again Pilsbury.
