Twin turbo Ram(360)
Old Jan 23, 2014 | 05:54 PM
  #71
aofarrell2's Avatar
aofarrell2
Originally Posted by ProjectTwinTurbo
Is it just a plug and play? And what's the price? Bc my plans are to turbo it. Then if it's acting like it's getting to much air then I'll upgrade injectors. If then it's getting to much fuel I'll push the boost up
MegaSquirts are not plug'n'play for our Dodges, but you can buy them pre-assembled, and then just do the wiring. All of our sensors will work with the MS, with the exception of swapping for a different MAP sensor, alot of guys use a GM 2 bar map sensor.
If you don't upgrade your injectors, they will be maxed out pretty fast, most likely even before you hit max RPM.
I posted that to give him an idea what is out there and give him a place to get ideas from.
Yes we can go 426 and 440 with the magnum motor.
Wow 440? on a small block mopar? Thought the 440 was the stock displacement of the big block mopar..
Old Jan 23, 2014 | 05:59 PM
  #72
ProjectTwinTurbo's Avatar
ProjectTwinTurbo
Ok we'll. if it was you guys. Would you turbo the engine. Or build it and if I build it still won't be very agresive. As in
Cam
Lifters
Springs
Everything I can get ported and polished
Oversized pistons
Valves
Rods
And modify the stock intake(don't wanna spend that much $ just on a intake manifold)
Or..... Swap for a 440 BB
Old Jan 23, 2014 | 06:02 PM
  #73
aofarrell2's Avatar
aofarrell2
Cam
Lifters
Springs
Oversized pistons
Valves
Rods
Okay, how much power you wanting to make? What's the application? Towing? Drag?
Old Jan 23, 2014 | 06:20 PM
  #74
ProjectTwinTurbo
Really there's no reason. I've had the truck passed down to me from my dad. Just wanna do something different it'll be my first vehicle but I want something different from any one else and just one of a kind.
Old Jan 23, 2014 | 06:22 PM
  #75
ProjectTwinTurbo
And horsepower I really don't care. The only thing the truck would be used for is hauling a fourwheeler here and there and going and tearing up a field. No mud or anything. And I'd like to be able to stop on it and it put ya in ir seat while still trying to keep affordable gas mileage.
Old Jan 23, 2014 | 06:23 PM
  #76
merc225hp's Avatar
merc225hp
It is, from 408 to 440 they offer it, same site as I posted before. Have a look around there lots to look at, even dyno sheets real dyno sheets.
http://www.performanceinjectionequip..._Assembly.html
Old Jan 23, 2014 | 06:28 PM
  #77
aofarrell2's Avatar
aofarrell2
Gas mileage is a bad word with these engines...
You'd be best camming your engine, maybe a different intake, some good tuning, etc. All bolt ons if all you wanna do is keep it cheap and make some put you back in your seat power. You'd be surprised how much a cam, intake, head port, headers, dual exhaust, tuning, etc. will do to wake one of these up.
Thanks alot Merc! Looks ALOT better than a Cambpell Performance stroking kit (and they only go up to 410)!
Old Jan 23, 2014 | 06:33 PM
  #78
ProjectTwinTurbo
What would u think of a 440 with just about a 650cfm carb and maybe a cam? What do u think that would compare to that setup? And what Milagros you think I'll get?
Old Jan 23, 2014 | 06:34 PM
  #79
Ham Bone's Avatar
Ham Bone
Those dyno sheets REALLY make me want to stroke my 360
Old Jan 23, 2014 | 06:35 PM
  #80
aofarrell2's Avatar
aofarrell2
Gonna need more than just a 650CFM. I've got a 675CFM on my 318 right now, and it's just right. And I've got a stock cam too.
And I get 12.5MPG right now, a 440 will just be a absolutely gas hog. Expect 4-6MPG.
