Good wheel backspacing?
Old Jan 24, 2014 | 07:25 PM
emattern06's Avatar
emattern06
Default Good wheel backspacing?
hey guys, i recently ordered 315/75/16 tires for my truck. I'm looking to get basic steel 16x8 truck wheels and want the tires to stick out past the fender by 1.5-2". What would be a good backspacing to achieve this? And yes i've read up on the forum all night, haven't seemed to find a solid answer. Thanks.
Old Jan 24, 2014 | 07:39 PM
merc225hp's Avatar
merc225hp
4"-4.5" will get you there.
Old Jan 24, 2014 | 07:57 PM
emattern06's Avatar
emattern06
Thats what i was thinking thank you. i was worried 4" would be too much
Old Jan 30, 2014 | 08:15 AM
ChillyPhil's Avatar
ChillyPhil
Not to bring this up again but the bigger backspacing means the tire will stick out more right?
And the smaller offset means it'll stick out further? Just trying to clear some stuff up.
Old Jan 30, 2014 | 09:02 AM
Backspacing determines how far out it sticks. Less backspacing means the tire/wheel moves outward from the axle.
Offset is just the distance from the mounting surface, to the center of the wheel. Two wheels with the same backspacing, but, different wheel width, will have different offset.
Old Jan 30, 2014 | 12:26 PM
ChillyPhil's Avatar
ChillyPhil
Alright so how would I be able to get mine out further then? I have 3.75 backspacing, 15x8 wheels. I was thinking of going 15x12 down the road.
Old Jan 30, 2014 | 01:02 PM
Wider wheels with the same backspacing will stick out further. Keep in mind though, that you are putting additional side loads on the already inadequate hub/bearing assemblies on the front axle. That is going to shorten their lifespan accordingly.
Old Jan 30, 2014 | 01:04 PM
ChillyPhil's Avatar
ChillyPhil
Yeah, unfortunately. I just want to have that wide, beefy look when I get these bushwacker flares down the road too.
Truck's already a money pit.
Old Jan 30, 2014 | 03:12 PM
FireDodge's Avatar
FireDodge
My previous tires were 315/75/16 with basic 16x8s with a 4.5 inch backspace. They stuck out about 1-1.5 inches.
