97 Dodge ram lighting issue
Old Jan 30, 2014 | 06:12 PM
Fsaienni22's Avatar
Fsaienni22
Default 97 Dodge ram lighting issue
Asking for a little help with my headlight issue on my 97 Dodge ram 1500. My headlights started to cut out on me when I tilted my steering wheel all the way down, but would come back on when I tilted it back up. Now they don't work at all no matter where the tilt is positioned. My high beams work just fine though.
Does anybody have a suggestion on what the problem could be?
Old Jan 30, 2014 | 06:55 PM
Welcome to DF. Most likely the wiring in the column is starting to short. Moving to the 2nd gen Ram section. They can help you.
Old Jan 30, 2014 | 07:32 PM
Pull the covers from around the steering column. Have a look at the wires in the multifunction switch connector. They are probably pulling loose. Common problem.
