1995 dodge ram 1500 5.9 oil consumption
Old Jan 30, 2014 | 03:44 PM
Ramking9610's Avatar
Ramking9610
Default 1995 dodge ram 1500 5.9 oil consumption
Okay, I've posted a thread about this before and I was told to do a compression test since my dodge was burning a lot of oil. My compression was perfect. It only smokes after sitting over night and dumps A LOT at 3k and over rpms. If I rev it over 3k for about 15 seconds the oil pressure will go to 0 and shut off the engine. I haven't noticed any power loss and JUST replaced the plenum with a hughes about 2 weeks ago. I was thinking that the valve seals are bad (I hope that's the problem). It feels like I have a gas cummins! Tell me what you guys are thinking
Old Jan 30, 2014 | 03:50 PM
Valve seals are a likely bet.
Oil pressure dropping to nothing, and the engine dieing isn't good though......
Old Jan 30, 2014 | 10:08 PM
Ramking9610
Also I forgot to mention..... I sometimes smell gas when I get out of my truck from a drive. Never paid any attention to it. It didn't start to happen until my truck started to smoke. I did some research and found out that the valves control the fuel to air mixture in the cylinders..... Might of found my answer?
Old Jan 30, 2014 | 10:26 PM
ReadRam's Avatar
ReadRam
You may have some leaky injectors...the gas smell. Holding rpm's at 3000 while in park is not helping your motor out..my opinion. Does it clatter under a load when accelerating?
Old Jan 30, 2014 | 10:32 PM
Ramking9610
The engine has PLENTY of power. I recently did the plenum and cleaned the injectors out and gave the intake, fuel rails, and intake a fresh paint job. I do here a little ticking noise when accelerating but I'm almost positive its a exhaust manifold leak. Also replaced pcv valve because it was soaked in oil.
Old Jan 31, 2014 | 09:19 AM
Valves merely allow stuff in/out of the cylinders. If your engine is running good, they are doing their job.
I would go lookin' for that gas smell though.
