98 ram 1500 5.2 4x4 vac line problem going to 4x4 shifter on front axle
Old Feb 3, 2014 | 12:00 PM
mbaron250's Avatar
mbaron250
Default 98 ram 1500 5.2 4x4 vac line problem going to 4x4 shifter on front axle
The steel lines going to vac shifter. One of steel lines near catalytic converter has an opening was wondering if it should be like that and if that would cause truck to not fully disengage from 4x4. Light is off
Old Feb 3, 2014 | 12:46 PM
Those are vacuum lines. If they have a hole in them, the front axle won't engage. need to fix that.
Welcome to DF!
Old Feb 3, 2014 | 01:02 PM
mbaron250's Avatar
mbaron250
Thanks hey you. It engages would it stay halfway locked into 4x4. Got a shake when truck goes into o/d gear and when I turn o/d off goes away
Old Feb 3, 2014 | 01:06 PM
One line will engage the front axle, other line is to disengage. If the hole isn't too bad, things will just move slowly. But, it will get worse as time goes by.
Shake in O/D is a separate issue. My guess is, if you check, you will find you are getting some misfire codes. (as that is what you are feeling...) More than likely you have a blown plenum, that is working on eating the front O2 sensor, and clogging your cat. Need to fix that too.
Old Feb 3, 2014 | 01:09 PM
Arde's Avatar
Arde
That's a common symptom of a misfire, truck shake in OD. Check plugs, wires, and cap & rotor, or just replace them, probably needs it anyway.
Old Feb 3, 2014 | 01:10 PM
mbaron250's Avatar
mbaron250
Thanks bro
Old Feb 3, 2014 | 01:11 PM
mbaron250's Avatar
mbaron250
Did plugs wires distributor and rotor and put a universal cat in too plus 2 o2 sensors thanks everyone for being nice
Old Feb 3, 2014 | 02:34 PM
Johnn123's Avatar
Johnn123
Did you check the plenum and fix it with a new aluminum plate? If not that work will quickly become done for nothing...
