new dodge owner any advice 1998 dodge ram 1500 2wd
Old Feb 3, 2014 | 01:17 PM
RADAR1913's Avatar
RADAR1913
Default new dodge owner any advice 1998 dodge ram 1500 2wd
ok guy thanks in advance for helping out I have a 1998 dodge ram 1500 5.2 with a 3.55 rearend i dont know what this truck has done to it not much i think but i have had the trans rebulit with a shift kit and i will be doing alot of towing and im getting about 230 miles and a tank and have a check engine light with code p1294 i looking for good mods and to fix all issues with this truck
this the bulid sheet for my dodge
According to our records, your vehicle was equipped from the factory
with the following:
*SX HD Vinyl 40/20/40 Bench Seat
-C3 Mist Gray
AMRS Storage Group - Behind Seat, Modular
APAS Monotone Paint
A05P #5 Engineering Development Zone
BAUS 117 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CKJS Black Vinyl Floor Covering
CSPS Passenger Assist Handle
CUVP Behind Seat Modular Storage System
CUYP Storage Tray
DGB All 4-Speed Automatic Transmissions
DGTS 4-Spd. Automatic 46RE Transmission
DHAP Lock-Up Torque Converter
DMDP 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
EAAC All Engines
EAGC All Gas Engine
ELF 5.2L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GNAS Rear View Day/Night Mirror
GPUS Manual 6 x 9 Black Mirrors
GVAC All Vehicles W/O Power Mirrors
HCAS Heater
HGBS Dash Liner Insulation
JAVS Instrument Cluster
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
KTXS BLACK - BADGE - DODGE, TAILGATE
LMAS Halogen Headlamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCTS Bright Front Bumper
MFDS Bright Grille
MHAS Black Windshield Moldings
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
NAA Federal Emissions
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
PW7A Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RASS AM/FM Cassette Radio
RCDP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Variable Assist Power Steering
SCBS 2-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
TBBS Full Size Spare Tire
TBMP Tire Carrier Winch
TR8S P225/75R16 BSW All Season Tires
TZAP Goodyear Brand Tires
WDKS 16X7 Steel Wheels
WLBP Steel Spare Wheel
WLYC All Steel Wheels
WMCS Bright Wheel Trim Rings
WMJS Center Hub
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
thanks
Old Feb 3, 2014 | 01:36 PM
moe7404's Avatar
moe7404
first check to see if it has the 7 1/4 axle housing. if it does change it to at least 8 1/4. the 7 1/4 would fail behind 6 cyl. and if it has the reg electronic ignition. get 2 ballast resistors put them in the glove box. at the first no start just swap it before you even check any thing.
Old Feb 3, 2014 | 01:58 PM
RADAR1913's Avatar
RADAR1913
ok will do that and the rear axle is 9.25 i think not sure i update the thread with a build sheet from dodge
Old Feb 3, 2014 | 02:43 PM
P1294 Target Idle Not Reached
Either a failing IAC motor, or, plenum is badly blown.
Old Feb 3, 2014 | 02:53 PM
RADAR1913's Avatar
RADAR1913
ok if the plenum is blown i was thinking of replacing the intake with the
Mopar Performance V8 Single Plane MPI Intake Manifolds 5007852
http://www.summitracing.com/parts/dcc-5007852/overview/
and a sct tune what do yall think
Old Feb 3, 2014 | 05:01 PM
Excellent choice. Although, if you look around a bit, I think you can find them cheaper.
Old Feb 3, 2014 | 05:26 PM
RADAR1913's Avatar
RADAR1913
is there another one that would work thats cheaper
Old Feb 3, 2014 | 05:59 PM
renardk764's Avatar
renardk764
http://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=1344
Old Feb 3, 2014 | 06:07 PM
Your link is kinda borked..... doesn't quite work. If you cut/paste though, it does work.
I am curious, what is the difference between that one, and item, and this one. It looks like the exact same manifold, but, it is under 300 bucks?
Old Feb 3, 2014 | 07:16 PM
RADAR1913's Avatar
RADAR1913
I am curiousas well, what is the difference between the two
