P0300 code
Old Feb 9, 2014 | 10:22 PM
Ram Driver's Avatar
Ram Driver
Default P0300 code
I know this is a multiple cylinder misfire code, so is my truck in need of a tune up or do you think the crank position sensor would cause this ?, or maybe a combination of both.
Ive had this truck about a year and a half, and I spent last year restoring the interior and having some suspension work done to it, so this year as soon as the weather warms up I will be having the plenum fixed, a tune up, and a few other things done.
Old Feb 9, 2014 | 10:43 PM
Do that stuff first. That should help quite a bit.
Old Feb 10, 2014 | 12:52 AM
horatio102's Avatar
horatio102
Could be a vacuum leak, fuel pressure/delivery issue, sensor issue, exhaust issue, or ignition issue.
Start with the obvious - check for vacuum leaks, monitor your sensor readings, fuel pressure, etc...
