temp sensor
Old Feb 11, 2014 | 08:01 PM
You get 5 volts on both sides of the temp sensor? That's either a bad sensor, or a short in the wiring somewhere.
Old Feb 12, 2014 | 07:36 AM
dangjake's Avatar
dangjake
I will check that next. Thanks for the input
Old Feb 13, 2014 | 05:35 PM
dangjake's Avatar
dangjake
No. Five volts on one side only. 1mv out less on the other. Now what? Bad pcm? If it was a short I would have 5 on both sides right?
Old Feb 13, 2014 | 08:19 PM
Correct. I have no clue what the correct voltages for output vs. temp are. I suppose the next step would be to plug a scanner into it, and read the data. See what the pcm thinks engine temp is, and see if the gauge in the dash agrees.
