Help with manual trans swap.
Old Feb 13, 2014 | 08:31 PM
  #21
BlackDakotaV8_4x4's Avatar
BlackDakotaV8_4x4
Witch ones do I need to jump to get it to start and witch ones so I can hook up my reverse lights?
[IMG][/IMG]
Old Feb 13, 2014 | 08:49 PM
  #22
You had image tags wrapped around html code. For the image tags, just a direct link to the pic is sufficient. With a "real" browser, Photobucket and the like provide and image link (just click on it, and it copies it to your clipboard, then just paste it into a post). I haven't used the mobile version of the site for anything other than to send one PM...... so, not entirely sure how it works on those.
Old Feb 13, 2014 | 08:55 PM
  #23
One wire should be hot with ignition on.
Center pin should be park/neutral indicator. (not entirely sure how that one works, I think the switch just provides ground path for the start relay control circuit.) (( yep, verified, center pin just goes to ground with the trans in park, or neutral.))
remaining pin is backup lights.
Old Feb 13, 2014 | 09:06 PM
  #24
BlackDakotaV8_4x4
Well it's the dang app that I'm using so idk I'll try the pic thing here in a min
Old Feb 13, 2014 | 09:07 PM
  #25
Pic for the neutral safety switch connector showed up fine.
Old Feb 13, 2014 | 09:12 PM
  #26
BlackDakotaV8_4x4
And there 8 wires going to that pigtail
Old Feb 13, 2014 | 09:16 PM
  #27
P/N switch should be a three pin connector. Its toward the front of the trans, right below where the shift linkage hits.
The 8 pin connector is for transmission control circuits. It's all about the governor, and O/D, and TCC solenoids.
Old Feb 13, 2014 | 09:23 PM
  #28
xjarhead69's Avatar
xjarhead69
That is the wrong pigtail, that controls the transmission solenoids.
Download the 96 manual.
On page 8W-80-35 of the manual it show's you what the connector your looking for looks like and what wires are what, there's only 3 pins.
HeyYou posted while i was checking manual.
Dave
Old Feb 13, 2014 | 09:28 PM
  #29
BlackDakotaV8_4x4
Witch wire in the 8 wire bunch will I have to jump or whatever to get the trans temp off of my dash because that bulb doesn't come out? And thank you for all of your help!
Old Feb 13, 2014 | 09:31 PM
  #30
BlackDakotaV8_4x4
Where can I download the Manuel for my truck or one close to it?
