Help with manual trans swap.
Old Feb 11, 2014 | 08:44 PM
BlackDakotaV8_4x4's Avatar
BlackDakotaV8_4x4
Default Help with manual trans swap.
I doing a trans swap. But what I need to know is will the pedals out of a 01 dodge ram fit a 97 dodge dakota?
Old Feb 11, 2014 | 08:45 PM
Call the dealer, and check part numbers for the pedal hanger. If the numbers are the same, should bolt right in.
Old Feb 11, 2014 | 08:48 PM
BlackDakotaV8_4x4
I really just need the pedals, you pull the pin out slide the new pedals in and put the pin back in
Old Feb 11, 2014 | 08:56 PM
hanger is the same for auto/manual? Interesting....... If you have the pedals, give it a shot, see what happens. If you don't, keep looking for Dakota pedals, and be sure they will fit.
Old Feb 11, 2014 | 09:11 PM
Spillage's Avatar
Spillage
If the assembly is the same, the components should be the same... no?
And whilst it might not be my place to point this out, a more descriptive thread title would be beneficial... when is the last time you typed "help" in a search for "pedals"?
Old Feb 12, 2014 | 01:15 PM
BlackDakotaV8_4x4
We'll I've done that because it seems like a lot of ppl will read the title and not what's inside, I'm looking for a lot of input on doing this swap, just was needing some help was all :/
Old Feb 12, 2014 | 02:06 PM
Edited the thread title a bit.
Old Feb 12, 2014 | 02:39 PM
BlackDakotaV8_4x4
Thanks, do y'all think you could help me with this? I've gotten little information from the dakota part of this site
Old Feb 12, 2014 | 03:06 PM
merc225hp's Avatar
merc225hp
Is there a place for me to get the Dakota parts book? Then I can compare part numbers. Part number for the Ram are not a problem but I don't work on little trucks lol.
Old Feb 12, 2014 | 03:50 PM
Have a look Here.
