Parts List help!
#41
#42
Yup. Only thing is...go with a different cam and you may find you cannot run 1.7s with it at all. You have to check your installed vs minimum height to see what you have to work with first, and you'll need your heads for that, though some of the guys on here will know the right numbers for certain combinations of parts. I for one am using stock springs so a cam install meant no 1.7s for me.
#44
I don't want to start a war here but I am 99% sure that stock heads are 5/16 because I had the H&S 1:7 rockers with 5/16 bolts at first but because I had asked Odessa to drill the holes out to 3/8's I had to get new rockers. Hopefully others can comment on which it is.
If you look at the Mopar RR kit it has 5/16-3/8 studs with the 5/16 in the head and 3/8 what holds the rockers. Which was one of the reasons why I didn't buy that kit because I would have had to buy studs too.
For the OP, if you're getting head work done anyhow it is nothing to have them drill out the rocker mount holes and tap them for 3/8's which is what I had done with my heads. Also I think if you look the Crane kit is 3/8's on both ends.
#45
I have a motor on the stand out in the garage, maybe I will go pull one, and see.
#47
I also believe the stock stud is 5/16".
Typically the only concern with increasing the stud size on stock heads, becomes is there enough meat left around the boss so they don't crack.
Since you're using aftermarket heads, the bosses are usually bigger to account for larger studs as that is a common upgrade on performance engines.
#48
#50
