Need help with CEL
Old Feb 14, 2014 | 06:28 PM
ngmillar's Avatar
ngmillar
Default Need help with CEL
Well I have P0400 code for EGR flow malfunction and a misfire in cylinder 4. I am aware our trucks do not have and EGR valve so wondering how I go about fixing this. I have reset the codes and they still come back so know I atleast have an issue somewhere. I was already about to replace my IAC(cleaned a few times already just gonna go ahead a get a new one) and O2 sensor(NTK). So are my two codes related by any chance and mainly I need help with the P0400 code the most. Thank you in advance and I have an 01 Ram 1500 5.9 with 207k miles on it.
Old Feb 14, 2014 | 10:45 PM
I have no clue why you would be getting a code for a system your truck doesn't have..... I would seriously consider getting a tuner, not only should it fix your EGR code, it will also get rid of the death flash, and torque management. You will like the power it frees up.
Old Feb 15, 2014 | 01:45 AM
Johnn123's Avatar
Johnn123
Welcome to Dodge Forum.
For the misfire, pull the plug and see what shape its in. Same with cap and rotor. If you havent changed them for awhile good opportunity to replace. Could do a compression test too, make sure its up to par.
Old Feb 15, 2014 | 02:11 AM
ngmillar's Avatar
ngmillar
Yea I was thinking the same thing I don't know if you recall but you replied to another thread I had a month or so ago about a code a got for something our truck doesn't have either...but tuner is hopefully something I can get this summer now that I have a second job I assume SCT from hemifever right ?
Old Feb 15, 2014 | 02:14 AM
ngmillar's Avatar
ngmillar
Within the last 2k miles I've done the plenum, regasketed all the way down to the head gasket, new plugs, wires , cap and rotor so I'm kinda hoping its just a faulty plug but a compression test will probably be in the near future. Also thoughts on possibly a bad(dirty) injector ?
Old Feb 15, 2014 | 10:53 AM
Yep, SCT from Hemifever.
Dirty injector is certainly possible. Could try swapping injectors on the bad cylinder, and the one next to it. See if the miss follows the injector.
Old Feb 15, 2014 | 01:08 PM
ngmillar's Avatar
ngmillar
Alright ill give that a shot today since I'm gonna be under the hood anyways.
Old Feb 15, 2014 | 03:29 PM
ngmillar's Avatar
ngmillar
Well my girlfriend was rushing me to go eat so i just got the new iac and o2 in and ran it for a few minutes. It was nice and smooth and no codes for now ill test drive it after I get this tie rod tightened up cause its "popping".
Old Feb 15, 2014 | 03:30 PM
Probably dry. Grease it if you can, replace it if you can't.
Old Feb 15, 2014 | 03:53 PM
ngmillar's Avatar
ngmillar
Just replaced all of it with grease-able parts but I just got under there and true to wiggle it and it has a little play cause the nut was tightened down so I can hear it "pop" when i turn the wheel and the nut hits the center link. Does that make sense? :-p
