Loud hum front end.
I have had a loud hum in the front passenger tire.
I have replaced ball joints, hub assembly, and shocks.
Still made the noise after all this work done, I have driven thousands of miles and it doesn't get worse. I drive about 100 miles a day depending If I work out of town.
Tires also dont seems to make a difference, noise happens accelerating or braking.
Noise gets louder making left hand turns, right hand turns make the noise almost go away.
I'm thinking it could be an alignment issue because the truck also pulls to the right a little bit.
2wd 2001 dodge ram 1500 extended cab, 5.2l
I would say like a mud tire is on one side, and it just sounds like a more aggressive mud tire when I turn harder. It's not a sounds that makes you cringe, in fact I was oblivious to it for months. My dad pointed it out to me and swore that a wheel bearing was going so I replaced it with a brand new one. My Grandad used it on his 2001 dodge (same everything) because his went out and it is working just fine. So i know for a fact its not the bearings in the front. But im 90% positive that its coming from the front passenger tire area. I have changed the brake pads a couple of months ago and that also didnt help or hurt anything. I'm going to measure between the front tires to see if my alignment is off. Although, there is no abnormal tire wear.
Under normal circumstances, your symptoms exhibit all the signs of a failing wheel bearing...... but, as you have changed it, and your truck is 2wd..... there isn't anything else left up there, other than.... the tire. Do you have the same tires front and back?
