Megaviper problem Electrical connection
Old Feb 16, 2014 | 11:06 AM
renardk764's Avatar
renardk764
Default Megaviper problem Electrical connection
The top photo is the original transmission and the bottom photo is the new Megaviper. Is there a connector I need to buy or am I FUBAR'd and have to contact patc for a replacement?
Old Feb 16, 2014 | 11:08 AM
Neutral safety switch, and reverse lights. Just swap the switch.
Old Feb 16, 2014 | 11:12 AM
renardk764's Avatar
renardk764
Thanks! That was an incredibly fast reply! Do I have to drop the pan or simply unscrew it and put the old one in?
Old Feb 16, 2014 | 11:16 AM
renardk764's Avatar
renardk764
Never mind. Figured it out :-)
Old Feb 16, 2014 | 11:55 AM
Late to the party, but yeah, it just screws in there.
Old Feb 16, 2014 | 01:13 PM
renardk764's Avatar
renardk764
Well you know you didn't make the appropriate sacrifices to the mechanic God when you drop a bell housing bolt into the factory y pipe. Ugh!
Old Feb 16, 2014 | 02:48 PM
LOLOLOL. Oh, that's gonna be fun to retrieve...... If your cat is gutted, just start the engine, and rev it a couple times, see if you can blow it out. (unless you have a muffler.... then it won't work, and you will have a rattle....)
Old Feb 16, 2014 | 03:35 PM
Spillage's Avatar
Spillage
Magnet on a stick... yea, I know, it will stick to the pipe, but if it gets to the bolt, it should drag it up the side if you go easy.
Old Feb 16, 2014 | 05:05 PM
renardk764's Avatar
renardk764
Got it. Now the torque converter/flex plate bolt holes won't match up. One is off.
Old Feb 16, 2014 | 06:09 PM
renardk764's Avatar
renardk764
This has turned into one of those patience testing projects. I gather this isn't normal and I'll have to have PATC send a replacement?
