Fixing A Sticking Tailgate Latch?
Old Feb 21, 2014 | 09:25 PM
JeremyMichael's Avatar
JeremyMichael
Default Fixing A Sticking Tailgate Latch?
How would I go about fixing a tailgate latch that does work, but it sticks? Meaning when I pull up on the handle it has no spring back motion, it stays latched upward until I push the handle back down to lock it in place.
Also, does anyone know where I can order a drivers side door hinge stopper bushing? My drivers side door hinge is fine and working, but the bushing inside of the stopper thing that limits how far it can open is loose and rotates when it shouldnt.
Old Feb 21, 2014 | 09:27 PM
Get a hinge pin kit. It comes with both the pivot pin, and the pin the 'stopper' rides on. Including the bushings.
My tailgate latch does the same thing. I just make sure to put it back down before closing the tailgate... hasn't been annoying enough for me to go after it yet.
Old Feb 21, 2014 | 09:31 PM
kejobe's Avatar
kejobe
For the tailgate, try lubing it (pb blaster, wd40, or whatever you prefer) and working it open and closed to free it up. Mine was doing the same thing. I squirted some pb blaster in there and worked the handle. After about a dozen times it worked like new.
Old Feb 21, 2014 | 09:36 PM
JeremyMichael
If I need to just replace the upper hinge pin, I don't have to really do anything but support the door right? I can have a person help me, but if I do that I have seen how much of a pain it can be to get the spring back in without the right tool, I'm thinking if two people do it we might be able to do it without having to remove the spring? Especially since the current bushing around the (stopper is loose and would fall right out?, but the new one would probably need hammered in?
Old Feb 21, 2014 | 10:31 PM
New ones just push in, and are held in place with clips. (nice and easy)
I suspect the spring would have to come out.... getting it back in could be fun. (finding it after it LEAPS out of there could be even more fun.... unless it hits you, then, it is easy to find, but, you got a nice bruise......)
One member suggested compressing the spring, using zip strips to hold it that way, installing it, and then cutting the zip strips...... as I don't really think there is enough room to get the tool in there to do it..... (I may try this....)
Old Feb 21, 2014 | 11:56 PM
Twmays's Avatar
Twmays
This for the sticky tailgate. Work both the handle and the latches on the sides.
