won't start smell gas
I have a 98 4x4 with a 318. My problem is that it won't start without me giving it gas. Once it starts I have to hold it above 1500 or so rpms to keep it running. If I let off the gas it dies instantly. Also when I'm cranking I smell gas pretty strong. I've done the plenum plate and there's no cat and also no front o2 sensor. Could the lack of an o2 sensor cause my motor to basically be drowning itself? It ran fine for 6 or so months before it just started running rough and now not at all. I'm not getting any codes either. I also just cleaned the throttle body and IAC and it didn't make a difference.
on
So you have to give it gas for it to start? I kinda wonder what your fuel pressure looks like, low pressure could explain that symptom, but the heavy gas smell is another thing. Have you visually verified that you don't have any obvious leaks? Maybe a torn or missing O ring on an injector....
You guys are both in Michigan......
Trending Topics
my 99 dodge was doing the samething i wouldnt start you could smeel gas real bad some mornings i would wake up and it wouldnt start at all i replaced the pickup in the destributor and the crank sensor the on the back of the motor on top of the flywheel and its been running fine ever since
