oil sending unit dilemma
Old 03-03-2014, 12:06 AM
horatio102's Avatar
horatio102
horatio102 is offline
Might seem too obvious, but have you checked the oil level? A customer's rig was doing exactly this and he was almost 2 quarts low.
Old 03-04-2014, 04:36 PM
06hemirunner97's Avatar
06hemirunner97
06hemirunner97 is offline
ok y'all I'm still goin at it with this truck i put a mechanical gauge on an it read right above 0 an it won't read till 4000 rpms an then it reads 25 i then turn the truck off an checked the oil it seems bone dry so I'm gonna get some oil in it an see if it reads different.
Old 03-04-2014, 04:59 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
You have a blown plenum, and are burning oil. It won't necessarily tell you that by the tell tale smoke either.
Old 03-04-2014, 05:47 PM
06hemirunner97
is a blown plenum a cause of burning oil an what is a plenum?
Old 03-04-2014, 07:28 PM
ngmillar's Avatar
ngmillar
ngmillar is offline
The plenum is the plate on the bottom of your intake...you may be able to see oil in the bottom if you open your TB and look down it and yes a blown plenum definitely causes oil to get burned
Old 03-04-2014, 09:13 PM
06hemirunner97
i did some lookin an I'm pretty sure theres oil in the intake..what all do i have to remove other than tb
Old 03-04-2014, 09:15 PM
HeyYou is offline
The plenum repair is an exercise. Read the be-all, end-all plenum thread at the top of this forum. The whole intake needs to come off, as the plenum plate is on the bottom of it.... (great plan there dodge....) It is at LEAST a days work to do. (unless you are experienced.)
Old 03-04-2014, 09:45 PM
ngmillar's Avatar
ngmillar
ngmillar is offline
Like heyyou said check out the plenum thread. I did mine in about a day and that was the first time I've ever worked on a car. Its pretty straightforward just find some write-ups on it and you will be golden. And the guys here are great about helping you out when you need it.
Old 03-04-2014, 10:10 PM
06hemirunner97
y'all have indeed been helping me with on point edvice i appreciate all the help you guys have given
Old 03-04-2014, 10:29 PM
horatio102's Avatar
horatio102
Well hopefully when you drain your oil it's not full of metal.
Quick Reply: oil sending unit dilemma
