98 ram 2500 smokes on start up
Old Mar 9, 2014 | 10:54 PM
  #31
ReadRam's Avatar
ReadRam
Maybe a leaking fuel injector, fuel smell. Did you remove injectors and use new o-rings upon reinstall?
Old Mar 12, 2014 | 04:58 PM
  #32
giulietti07's Avatar
giulietti07
Okay so truck still smokes on star up and start up only if its been sitting for a fee hours...could this be valve seal?
Old Mar 12, 2014 | 05:30 PM
  #33
Highly likely.
Old Mar 12, 2014 | 07:01 PM
  #34
giulietti07
to do the valve seals does the plenum have to come back off?
Old Mar 12, 2014 | 08:48 PM
  #35
aofarrell2's Avatar
aofarrell2
No.
You will need to remove the valvecovers to get to the valves.
You can replace the valve seals without removing the heads.
You will need a adapter that puts compressed air in the cylinders to hold the valves up, and a overhead valve spring compressor. Essentially you put compressed air in the cylinders to hold the valves up so that they don't drop into the cylinder.
Old Mar 17, 2014 | 10:21 PM
  #36
giulietti07
Gonna be doing valve seals this weekend hopefully that'll fix it
