Fuel leak
Old Mar 10, 2014 | 09:49 AM
Mh98's Avatar
Mh98
Angry Fuel leak
Hi guys, need some help here. I had a pretty bad leak at the quick connect/fuel pressure regulator. I replaced the nylon section and put a new quick connect on there. Still leaking. It's dripping out the front of the quick connect, which is snapped on tight. I guess I don't know what else to try besides a new FPR, but $115 for guess work is not what I feel comfortable with. Any ideas or anyone else ever have this problem?
Last edited by Mh98; Mar 10, 2014 at 09:52 AM. Reason: some ridiculous amount of txt showed up on screen
Old Mar 10, 2014 | 10:26 AM
snowboundrmk's Avatar
snowboundrmk
Make sure you have the right size quick connect. I think some trucks used 5/16" and some used 3/8". Also make sure the connector has the gasket in it and its seating right. The regulator could be damaged too. Fuel leaks aren't fun.
Old Mar 10, 2014 | 10:34 AM
Mh98's Avatar
Mh98
Yeah they suck. It's the right size, 3/8. Dealer gave me the part #. I was wondering if I have some hairline crack in the regulator where it plugs in. I am just apprehensive when it comes to spending over $100 to guess. The only thing I know is that it has to be the connector or the regulator.
Old Mar 10, 2014 | 10:39 AM
Mh98's Avatar
Mh98
Also, I assume the connectors have all the seals already in them, correct? I can see a yellow o ring in it.
Old Mar 10, 2014 | 11:03 AM
Take it back apart, inspect the nipple on the regulator, make sure is isn't damaged. Also check the o-rings in the connector. If you nick one, it will leak.
Old Mar 10, 2014 | 11:08 AM
Mh98's Avatar
Mh98
Ok, I will try that tonight when I have time. I will follow up in the morning. Thanks
Old Mar 10, 2014 | 11:32 AM
snowboundrmk
If the regulator is bad it might not be a bad idea to just buy a whole new pump.
Old Mar 10, 2014 | 12:03 PM
Mh98's Avatar
Mh98
I was hoping I could avoid that but you're right. We'll see
