Motor
Old Mar 10, 2014 | 03:50 PM
Mahathey's Avatar
Mahathey
Default Motor
What all is needed to put an auto engine on a 5 speed tranny?
Old Mar 10, 2014 | 04:33 PM
Rescue35's Avatar
Rescue35
Use a flywheel instead of a flex plate.
This is the simple answer to your simple question. If there are any more specifics you would like to share it might help. Such as engine year, vehicle year, if the engine is all thats being replaced, etc.
Old Mar 10, 2014 | 06:00 PM
AtomicDog's Avatar
AtomicDog
You will also need a clutch disc, pressure plate and throw-out bearing at a minimum. The vehicle should also have a clutch pedal and the appropriate linkages.
Old Mar 10, 2014 | 06:07 PM
SpcD1500's Avatar
SpcD1500
You will need to ream or die grind the end of your crank to 1" because the pilot bearing will not fit in the crank of an auto engine. You must be very careful not to take to much out cause the pilot bearing will fall out and if you take to little and force the bearing in it will deform it and could be enough to lock the tranny and crank together making the clutch useless. I have been down both of these roads.
Old Mar 11, 2014 | 09:49 AM
P1NKST@FF's Avatar
P1NKST@FF
Bolts
Old Mar 11, 2014 | 10:38 AM
frankie_b_jr's Avatar
frankie_b_jr
I don't know about the 318, but on the 360 you don't need to ream anything out. You can get a pilot bearing with a bushing from your local parts house.
It sounds like you're swapping an auto equipped engine into a manual truck (sorry if I'm ASSuming wrong). If that's the case, you'll need the pilot bearing with bushing, crank sensor (wouldn't hurt to replace even if yours is good), and new clutch hardware while you're in there.
More info about your truck and engine would help a lot, as previously mentioned.
Old Mar 11, 2014 | 01:32 PM
Mahathey's Avatar
Mahathey
Thank y'all very much!
Old Mar 11, 2014 | 03:39 PM
aofarrell2's Avatar
aofarrell2
You do NOT need to ream it out. The crankshafts are the same between the two engine. If you do need to modify the crank you have the WRONG pilot bearing.
If you want more info on the swap PM me and I can help you, I have done the complete swap.
Old Mar 11, 2014 | 04:19 PM
merc225hp's Avatar
merc225hp
Why pm? post your info here in this thread where others can read it.
Old Mar 11, 2014 | 04:21 PM
aofarrell2's Avatar
aofarrell2
I'm not going to type it all up if he ain't serious about the swap.
If he comes back serious I'll post it up here.
