new timing chain installed
Old Dec 17, 2022 | 12:27 AM
CD vines's Avatar
CD vines
Turn the engine until you are SURE #1 is at TDC on the compression stroke, see where the dizzy is pointing.
From where the dizzy points and then what put that plug wire on the cap and is firing order the same from where it points like it'll go 65721843??
Old Dec 17, 2022 | 11:05 AM
#1 should be marked on the cap. With number 1 at TDC, firing position, the rotor should be pointed at the notch in the distributor body. Firing order from there is 1 8 4 3 6 5 7 2. Clockwise rotation.
Old Dec 17, 2022 | 06:10 PM
CD vines's Avatar
CD vines
It point at six tower but my wires don't reach
Old Dec 17, 2022 | 06:19 PM
CD vines's Avatar
CD vines
Should I just start all over
Old Dec 17, 2022 | 06:36 PM
If it is pointing at six, you need to roll the engine over once.
Old Dec 17, 2022 | 06:46 PM
CD vines's Avatar
CD vines
then what I've got it out back together already but I can tear back into quick and how much slack should I have in the chain
Old Dec 17, 2022 | 08:24 PM
No need to tear it apart, with the plugs out, just grab the crank pulley, and roll the motor over by hand. It'll be stiff, but, it's doable.
Old Dec 18, 2022 | 01:41 AM
CD vines's Avatar
CD vines
Okay then what after that I don't even know what I'm looking for I'm an idiot please be more specifc
Old Dec 18, 2022 | 11:40 AM
Turn the engine so the rotor points at the number 1 post on the distributor cap. Set up your plug wires accordingly. If you haven't moved the distributor, or turned the cam/crank independent of each other, it should start and run.
