Drinking gas
Old Mar 20, 2014 | 10:10 PM
eddiekimberly's Avatar
eddiekimberly
OK, I will add that to my list of things to check. Could the MAP be bad without a code?
Old Mar 20, 2014 | 10:38 PM
dhvaughan's Avatar
dhvaughan
temporarily unplug front o2 sensor harness. it'll trigger a cel for bad O2 sensor, but ignore that and see if it runs any better or smells any better. that'll force it to run on default tuning and stay in open loop. it'll run a little less than optimum, but it should run fine.
remove the spark plugs and see if any one or two look bad or wet. that would indicate lack of spark or some kind of injector problem.
i doubt that map or tps is bad w/o a cel saying so.
Old Mar 20, 2014 | 11:17 PM
What brand O2?
Old Mar 21, 2014 | 12:05 AM
jholaway1971's Avatar
jholaway1971
Years ago I had a 80's something Buick skylark that did the same thing as you are describing and it was a cracked mechanical fuel pump that was dumping gas into the engine oil. I know almost all of these trucks have the fuel pump in the gas tanks but was wanting to point that out just in case you have the fuel pump on your engine instead of the tank.
Old Mar 21, 2014 | 02:01 AM
Ram Driver's Avatar
Ram Driver
Yes, any part can go bad, and not always trigger a code. I have had it happen to me on my 08 dodge ram.
Old Mar 21, 2014 | 07:39 AM
eddiekimberly
Don't remember the O2 sensor brand. DO rememeber its not a Bosch. Got it from RockAuto. I will run some of these checks and see what I can come up with.
