Trans Shifting Issue
Old Mar 22, 2014 | 06:25 AM
Walnutcrazy's Avatar
Walnutcrazy
Default Trans Shifting Issue
I have a 2001 dually with the 5.9L Cummins 24 valve and it intermittently does not go into gear. This is very random, but once in gear it shifts fine. This has a Suncoast valve body with recent fluid and filter change. Any ideas?
Old Mar 22, 2014 | 12:33 PM
Does it not shift? Or, when you first go to drive it, the gear you select doesn't engage? I am assuming auto trans......
Old Mar 23, 2014 | 07:57 AM
Walnutcrazy
Default 2001 Trans Shifting Problem
The issue occurs sometimes after sitting and also after is it warmed up and shifted several times. You move the shift lever and it does not engage, return to park and wait (not time dependent) shift again and it may engage or not. Eventually it will engage. This is using a Suncoast valve body with a PCS controller. Have just drained the pan and removed the filter, fluid looked and smelled OK. Not sure about the filter. Did not see any obvious problems or loose wires in the valve body area. Local transmission shop believed the problem was with the pump and resurfaced the pump face in Dec and this did not fix the problem. He said he could find no other problems and wants to blame the PCS controller.
Old Mar 23, 2014 | 10:17 AM
newman1367's Avatar
newman1367
That's some helpful info. I bet the controller is fine but a problem in the wiring. To use a PCS controller, don't you have to tap into the wiring harness? I thought you did and if so, there might be a bad connection. But then again electronics are temperamental and if all connections are good, it may be the controller.
