"O/D Off" engaging when driving on interstate
When driving for anything more than 30 minutes in overdrive, the "O/D Off" indicator illuminates and I am unable to shut it off. After doing some research, it appears that the 46RE has some sort of overheat protection that causes this. If this is accurate, what are some causes for the overheating? I have felt the hoses and it seems that that cooler is doing its job. This happens even if it is 10 degrees F outside. If the overheating thing is not accurate, any other ideas?
The transmission will sometimes slip in first. Second gear engagement is also unpredictable when under light throttle during the 1-2 upshift. If I put the gear shifter in the "1" position, the slipping condition goes away. This leads me to think I have a bad overrunning clutch. Could a bad overrunning clutch be causing the overheating when driving on the interstate thus causing the "O/D Off" light to illuminate automatically?
Vehicle Information:
2001 Dodge Ram 1500
4x4
Extended cab
96000 miles
2001 Dodge Ram 1500
4x4
Extended cab
96000 miles
