"elp" unkle clusters in trouble
Old Apr 7, 2014 | 03:19 PM
poorvet's Avatar
poorvet
Default "elp" unkle clusters in trouble
96 5.2 cluster temp / volt not working autozone said change this change that "wtf",so i did cleaned up any ground wire the eye can see,put atest light on the 2wire thong im prong light came on one side of cable prong,connecter if u will,dont know if there is afuse cince oil,rpm,speedo work,any help is good help
Old Apr 7, 2014 | 03:30 PM
O.M.G. What language is this?
Old Apr 7, 2014 | 03:49 PM
Darren270's Avatar
Darren270
It appears to be authentic frontier gibberish.
Old Apr 7, 2014 | 10:04 PM
i4got68's Avatar
i4got68
Please remember to talk in proper sentences and have somewhat proper grammar.
From what I can piece together, you're having problems with your temperature gauge and your voltage meter on your gauges. So you changed your dash cluster and cleaned your grounds. Now you're asking if there's any fuses or circuits that could cause a short in the system?
Is this translation somewhat correct?
Old Apr 7, 2014 | 10:25 PM
poorvet's Avatar
poorvet
thank u for looking,sorry about the jibberish,just got lost in transulation,and my grammers my human code to ween out hacks,now 4 the real stuff, info on the post is greatly apreiciated as i look to the most knowelegable persons on the web[2nd gen ram]family any help is good help
Old Apr 7, 2014 | 10:41 PM
poorvet's Avatar
poorvet
hello again ,i did change the coolant tempature sencer *** well as the tempature switch,now the cluster on the other hand no i did not change ,every other gauge rpm/oil/speed works,but if its the cluster i will be doing so ,now if this helps just bought this buitifull excab 2 week ago high mil but runs like a champ,the guy i got it from jump it to start ,ran,then got a fresh used battery from another truck hook cables on wrong sent sparks a flying,thinking could have fryed somthing so i look to you`s for help as i am a diy..er
Old Apr 7, 2014 | 11:15 PM
sam3293's Avatar
sam3293
Is there another language you prefer to type because half your stuff is misspelled and very bad grammar. Try reading it before u post.
Old Apr 8, 2014 | 12:03 AM
Ham Bone's Avatar
Ham Bone
disconnect your battery and drain the system. Cut the headlights on or something. Then hook everything back up and try again
Old Apr 8, 2014 | 07:46 AM
I can't even read your posts.
Old Apr 8, 2014 | 05:56 PM
poorvet's Avatar
poorvet
i ask for help not grammer correction,is this site about dodge trucks/cars or about correcting one person misspelled words when the person reading ,knows what it means ,does such aperson discriminate a vet because of grammer issues
