01 ram 1500 grinding/vibration
Old Apr 14, 2014 | 11:23 AM
dragracer501's Avatar
dragracer501
Default 01 ram 1500 grinding/vibration
i have a 2001 ram 1500 with the 5.9 and 160,000 miles when hit 77 mph it starts to grind and i dont know what it could be if its like the output on the transfer case that broke and is loose or if wheelbearings are bad or a ujoint is gone because the trans just got rebuilt like a month ago and its still bad. Any help is very appricieted.
Old Apr 14, 2014 | 11:34 AM
Moving this to the correct section.
2 or 4 wheel drive?
Old Apr 14, 2014 | 11:40 AM
Ramman18's Avatar
Ramman18
Try replacing ujoints in driveshaft. Easy, cheap and will cure many issues. I just did this and made a world of difference.
Old Apr 14, 2014 | 01:50 PM
dragracer501
its a 4 wheel with the axle disconnect and its diconectedd so its not the front drive shaft at least
Old Apr 14, 2014 | 02:19 PM
Drop the rear driveshaft, pull the tailhousing off the t-case. See if the snap ring that is supposed to be right next to that rear bearing is still there.
Old Apr 14, 2014 | 03:22 PM
dragracer501
what could it be if its in the front end?
Old Apr 14, 2014 | 03:29 PM
Inspect EVERYTHING in the drivetrain. Since it does it on the freeway, you can probably ignore the front drive shaft, but, check EVERYTHING else.
Old Apr 15, 2014 | 11:45 AM
Ramman18's Avatar
Ramman18
I said DRIVESHAFT not AXLE SHAFT. The big tube that goes to the rear pumpkin>? Yeah, that one has two u-joints in them. I would never ever have supposed you were driving 77mph in 4 wheel drive on pavement.
Old Apr 15, 2014 | 05:15 PM
dragracer501
ok well i will have to get sometime so check everything its more annoying than hard on anything
