Grinding sound at 70+mph
Old 05-13-2014 | 08:12 PM
JSTMoto's Avatar
JSTMoto
While you've got the cover off, is there side to side play in the differential? Can you move it left or right any?
Park on flat ground, chock your tires, put transmission in neutral, and crawl under the truck and push/pull your drive shafts at each u-joint with all your weight. Is there any play in them? Front axle u-joints new?
Does it make a difference if you are driving and hear the noise and you shift the transmission into neutral? Do NOT overshoot and accidentally go in to reverse at 70mph.... I think you can just bump the shifter up in to neutral without having to pull it towards you.
just ideas...
Old 05-13-2014 | 08:28 PM
Ham Bone's Avatar
Ham Bone
Everything seems tight.
All u joints in the driveline are less then 4 months old. All moog problem solvers.
Waiting for rtv to seal before filling up. Going on a test run tomorrow morning. Hopefully my problems will go away
Old 05-14-2014 | 09:28 PM
Ham Bone's Avatar
Ham Bone
Well now it's seems that it's nice and smooth until the truck is warmed up. Then it comes back. Could be my imagination.
Idk, diff oil change seemed to help some. But still something wrong. Sorry I know that's not very helpful.
Soooooo, any other ideas? Getting an alignment tomorrow and gonna change the front diff fluid this weekend.
Looks like I will be checking wheel bearings this weekend also.
Running out of ideas though....
Old 05-14-2014 | 09:51 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
when the truck gets aligned they will check wheel bearings and all front end. my vote is front diff.
Old 05-14-2014 | 09:56 PM
Ham Bone's Avatar
Ham Bone
I just had it in inspected. They check everything pretty thoroughly. They found bad wheel bearings last year. But that was with the 44.
So what do you think is wrong with the front diff?
Old 05-16-2014 | 08:55 PM
Ham Bone's Avatar
Ham Bone
Ok I got an alignement. It didn't help. Front diff was pretty low on fluid. Couldn't fill any just poking my pinky in and feeling a round.
Filled that up and took a test drive. Still there at 75 mph.
Played around with 4x4. Everything seemed to work fine. Only odd thing was in 4 lo going in reverse I could here a faint whining/whirling sound.
Help!
Old 05-17-2014 | 08:18 AM
MaxPower1971's Avatar
MaxPower1971
My 1500 did that. I must've replaced everything before I noticed the long drive shaft had lost the balancing weight....
Old 05-17-2014 | 08:54 AM
Ham Bone's Avatar
Ham Bone
Ok I'll look into that this evening!
Thanks. I'm Into those weird things at this point
Old 05-17-2014 | 10:50 AM
Whining/whirring in 4lo is pretty normal. Got that gear reduction thing going on in the t-case.
Old 05-17-2014 | 11:25 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
pull front cover and inspect gears.
Quick Reply: Grinding sound at 70+mph
