help please
Old Apr 29, 2014 | 07:25 PM
tyrellgower's Avatar
tyrellgower
Question help please
I need help I have a 1994 dodge ram 1500 and I had to get another motor I have a 5.9l and I swapped it with a motor from a 1999 and I cant get it to start
Old Apr 29, 2014 | 07:26 PM
Ham Bone's Avatar
Ham Bone
Did you swap pcms?
Old Apr 29, 2014 | 07:29 PM
tyrellgower
Default no
No do I half to
Old Apr 29, 2014 | 07:36 PM
tyrellgower
Default will it work
Will that fix the problem I get misfiring and no starting can I just swap the sensors from my old motor to my new one both engines are 5.9l 360's
Old Apr 29, 2014 | 08:18 PM
Yes, you can, in fact, I would recommend it. Problem is, the 99 intake manifold won't have a provision for the temp sensor for the in-dash temp gauge. Make SURE you at least hook up the two-wire temp sensor.
Old Apr 29, 2014 | 09:29 PM
tyrellgower
Ok just to make sure, I can just put the sensors of my old 1994 engine on this 1999 engine and I will run
Old Apr 29, 2014 | 09:31 PM
Arde's Avatar
Arde
Right.
Old Apr 29, 2014 | 10:23 PM
tyrellgower
Ok cool I'll do that and see what happens cause I love this truck it the first 4x4 I've ever had and I pulls like crazy but thinks for the help if I have any more problems ill let you know
Old Apr 30, 2014 | 09:38 AM
redneck_ram's Avatar
redneck_ram
did you replace the crank sensor after you installed the new motor?
those sensors are known to get destroyed when removing, and installing engines/transmissions.
Old Apr 30, 2014 | 10:28 AM
tyrellgower
Well I put a 1999 cps on but thin I swapped it to the 1994 cps but its not new an I've tested it and tests fine should i use the distributor from the 1994 engine to
