Recommended cat?
MAPP gas is stabilized acetylene. Not quite as hot as acetylene but much hotter than propane.
I tried a sawzall, but not really worth it. That pipe is damn tough.
HeyYou, I didn't know you could heat that pipe up and slip it out. Usually I just cut them out with a torch and then have someone with a MIG weld the new one in.
Take a chizle or a flat head screw driver and gently tap it betweened the slipped pipes. Flair out the end of the intermidiate pipe tiny bits at a time all the way around the whole pipe until you can work out the end of the cat. You can still get a perfect seal with an exhaust clamp once the new cat is in. I did this and it worked like a charm.
If your intermidiate pipe is suuuuper rusty and old this could be a riskey, you just don't want to get crazy and bend the crap outa the end your intermidiate pipe or chip and crack pieces off if its really rusty.
Even pipes that were clamped together (and thus, somewhat deformed by the clamp) will come apart with a bit of convincing.
