t-case saver
t-case saver
I've seen some vids on this Gilly's transfer case saver reason is the C-clip on the output shaft breaks this is a two piece sleeve that bolts in place of the C-clip
Has anybody had any problems with this I get a bad clunk going in reverse just a thought the shaft is moving in and out don't want to break anything in my transfer case any help Thanks
Trending Topics
Yes definitely get one, mine was snapped and I believe caused me to have worn parts in my case that I replaced.
Installation is real easy, take out the drive shaft, take out 4 bolts on tail shaft and pull it off. Then put the tcase saver on(use loctite) you may have to move the output shaft a bit to get it lined up. Use some rtv to put the tailshaft back on throw in the driveshaft and viola! haha
