High Idle but also sometimes stalls at idle
Old 06-03-2014, 06:23 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
With an analog meter, you can properly test it. A short would just five you the full five volts, open would give you zero. The needle needs to sweep smoothly up the scale, if it doesn't, it's bad.
  #22
Old 06-03-2014, 08:08 PM
Dakota1089's Avatar
Dakota1089
Dakota1089 is offline
I will try to get an analog one to test again. For now I'm actually going to start with replacing IAC. Because it was dying out on saturday as well, and i know cleaning it was just a temp fix anyway its probably a good start. Plus i drove it today and didn't get freeway surge again but it would surge 50-100 rpm at idle and also got a high idle in park again. So between saturday and today I'm feeling that might be the culprit... will report back. How do reset after replacing it?
Quick Reply: High Idle but also sometimes stalls at idle
