1998 ram 1500 sport to cummins diesel swap
Old May 12, 2014 | 10:54 PM
  #21
Originally Posted by Rambo722
Ok thanks and it needs to be a ram 3500 right
2500's came with der diesel as well. One tons will be dual rear wheel. ALL of them were. So 2500 is what you really want.
Old May 13, 2014 | 12:51 PM
  #22
Rambo722's Avatar
Rambo722
Okay and what about the wait to start light in the instrument cluster in the dash. Is there a way to get that light or will I just have to live without one?
Old May 13, 2014 | 01:24 PM
  #23
Rambo722's Avatar
Rambo722
And could I use a 24 valve or does it have to be a 12v
Old May 13, 2014 | 02:40 PM
  #24
24 valve is mostly electronically controlled. You *could* use one, but, it would be more complicated. (would have to change over the electronics, and also the interior wiring, dash, etc.)
Wait to start light is there in the dash, not sure what it would take to make it work. (put a bulb in it, and see what happens.)
Old May 13, 2014 | 02:42 PM
  #25
Johnn123's Avatar
Johnn123
^HY is right on, a 24v is doable but will be much complicated then a 12v install.
You're also going to have to swap the entire fuel system out as well
Old May 14, 2014 | 01:19 PM
  #26
Rambo722's Avatar
Rambo722
Oh ok thanks for the advice
Old May 14, 2014 | 01:22 PM
  #27
Rambo722's Avatar
Rambo722
John123, what engine is in your 01 ram 1500? Do you have a diesel in it?
